NC30 headstock stand
bikemonkey
Post by bikemonkey »
What's the pin size needed?
Plus has anyone got any knowledge of these:
http://www.ebay.co.uk/sch/i.html?_sacat ... nd&_sop=15
Seem a bargain.
VFRkieran
Bike owned: NC30, NSR250, CBR600, TS125
Re: NC30 headstock stand
Post by VFRkieran »
Off the top of my head its a 31mm pin that you will need, will measure tomorow for you if nobody else replys confirming it.
brido
Post by brido »
Yes I have one of them stands and they are a good job, no problems with it.
bikemonkey
brido wrote:Yes I have one of them stands and they are a good job, no problems with it.
What bike do you use it for?/If it's an NC30 do the pins that are supplied fit?
speedy231278
Post by speedy231278 »
Seems incredibly cheap, or are the ones in the UK for £60-odd just a rip-off? The pins aren't quite big enough for an NC35, and I'm led to believe that the diameter of the stem on a 30 is bigger still. They still work with a smaller pin, it's just a little sloppy.
Baz
Bike owned: VFR NC30 (91)
Post by Baz »
I bought one and used it for the first time today. The build quality is very good but the pins supplied are nowhere near big enough! I have had to use the biggest pin supplied with a 21mm socket slipped over that just to make it fit.
The socket is a perfect fit into the stem so just need to get it welded permanently to the pin to sort it properly. (or just buy a bigger pin that fits!)
bikemonkey
Might message them, see if they can turn up a bigger pin.
Still need to know the size though....
VFRkieran
Post by VFRkieran »
mines 27mm measured it earlier with the verniers on for you mate.
bikemonkey
VFRkieran wrote:mines 27mm measured it earlier with the verniers on for you mate.
Awesome, cheers :up:
NGneer
Post by NGneer »
bikemonkey wrote:Might message them, see if they can turn up a bigger pin.
Monkey
Did you get in touch with them about suppling these with a larger pin? What size would you go for, the full 27mm (snug) fit or more like a 26mm to allow for the inevitable rust and crud that will be in there?
If you want any help, the Girlfriend is German and could do the translation if needed ;)
