NC30 rear exhaust removal
katana
Well project VFR has started.
Have taken the rads off and they need a clean but that will be another post. I was wondering how to get the rear exhaust off the rear manifold. The bolts as usual are so rusted they have are no longer a shape.
Is there an easy way to remove them? Or is it a rear subframe off and hock out sort of job?
mick.mh2racing
Re: NC30 rear exhaust removal
If bolts are rounded then it's probably seat unit off and attack with whatever you have to hand.
How hard can it be?
katana
Arse. I didn't fancy doing that as I'm doing this outside at the mo as the garage is full.
mick.mh2racing
Have a go with something like a 10" extension bar with whatever socket you can get to fit and you might get lucky.
How hard can it be?
http://www.ferret.com.au/c/Loctite-Henk ... nt-n672370" onclick="window.open(this.href);return false;
that stuff is amazing at jobs like this.
