m-max
Re: m-max
motrax
there are some others as well but the M-Max is Motrax. If you can't find one fit a GOLD kmh to mph converter box. The gold ones fit at the wheel end of the speedo cable as there isn't enough room by the clocks
Re: m-max
No ... the wires from the M-Max plug into the the loom at the back of the clocks instead of the speedo wires. It's useful if you want to put the bike on a dynoTaggy wrote:does the speedo need to be connected if you have an m-max fitted?
