VFR Engine valve bounce help.
Re: VFR Engine valve bounce help.
That won't account for it only revving to 2500 rpm, it will still hit redline on only 2 cylinders.franna16 wrote: mmm i wonder if one of my coil pacs arent working.
I'd guess you have a serious issue, sounds like a big end failure to me.
CMSMJ1 wrote:I'd reckon on getting a bike that worked before wasting money on fancy pants tyga anything..
no point with a bike that looks good and doesn't go.
My tuppence is on shagged big end bearings - apart from blowing my race bike up by a vlaves to piston interface - all the dead NC engines I have seen (and had) are big end failures due to low oil.
you need to get your hands on some tools too - rotating the motor with a 14mm socket lets you feel the resistance nicely, using a spanner does not give you that.
good luck with it - there are a few guys up your way I am sure.
I agree with you .
I think I’m over the whole HRC/Tyga thing. I will get the bike running stock . Maybe Replace the engine if its cheaper. Extra money will go into either a KLR 650 or a new car or my race bike (Body kit needs work). If anyone has winning Lotto Numbers for me your welcome to pm them.
But I like this forum. All the British colonies working together hehe.
I'm learning allot as well. and Sorry if I sound like another Scottish member here hehe. I'm a bit of a know it all at times
As for the socket to rotate the motor. I've already bought one today. Only used the spanner to see if I could actually get the engine to turn without too much force.
As said above would wager that it's the big end bearings. I have a track bike that along with a modded tap and sticking float valve diluted the engine oil with fuel. Top End cams etc appear ok it runs but has developed a noise similar to what you've described its hard to locate exact source but seems to be coming from the crankcase area between the v which would back up what cmmsj1 and cammo are saying.
