1WG Engines??
goonerruss
1WG Engines??
Hi all, can anyone tell me how many types of FZR400 1WG engines there are? Have recently got a 2nd hand engine and my mechanic friend reckons it doesn't have the same mounting points? can anyone clarify this, thanks
- Motorcycle Solutions
- Bike owned: Kawasaki ZX9R E1
Re: 1WG Engines??
what is your frame number and original engine number / and does the other have mountin hole on the cylender head..
Taggyd
Re: 1WG Engines??
the genesis models have different mounting points i think?
sharpey
Re: 1WG Engines??
not massively helpful but sure you could make any thing fit just use a hammer and angle grinder, its what i do for taggy lol
Re: 1WG Engines??
True but then maybe Goonerrus will be able to spot the differencesharpey wrote:not massively helpful but sure you could make any thing fit just use a hammer and angle grinder, its what i do for taggy lol
All the engines are helpfully marked 1WG theres no engine numbers.
As said the 3TJ engine has mounts on the cylinder head.
Exup engines mount with frame rails to the bottom front (HA HA front bottom
Don't know about the Genisis
Ant the original steel frame FZR is black
