I have a 92 super four.
I recently changed the oil, cleaned the carbs spotlessly and set them up asper here http://www.factorypro.com/tech_tuning_p ... gines.html, new Denso sparks, new airfilter.
Before I did any of this it bogged very badly from 5k -7k no matter the gear.
Since the changes the bike runs utterly amazing in every range apart from the 5k -7k area. It really starts to notch up the torque from 4k - 5k and then hits a wall, this is really a nice range for commuting and i'd like it to work :). I dont think it is the needle height or to do with the main jets as I have tried various setups which do not affect this range at all.
Two things I have heard it could be
1- the Helmholtz effect... the airbox is not working properly with the carbs caused by piston frequency vs helmholtz of airbox. ( i dont think it is this)
2 - The clocks... could the resistor on the CDI trick sort this out.
Any help from people who also have had this problem would be appreciated.
