Rebuilding the whole wiring loom
alexandervf
Bike owned: NC35
Re: Rebuilding the whole wiring loom
Post by alexandervf »
First of all i would like to thank you for your comments, good or bad.
I am just a simple rider who will enjoy anything that has to do with fixing upgrading or finding new things.
The good wire quality has nothing to do with higher loads and such things.Did i mention something like that?
I am not building a nasa satellite.
The fact that the small currents will flow better through this wiring has nothing to do with how much load can these wires take.Are these wires used only when high loads are required?
I find your comments "tacky and outstanding" a little bit controversial. :-?
Maelstrom
Bike owned: MC22, 3TJ1
Post by Maelstrom »
Well that is why I should and do try to keep my opinions to myself, most of the time. My reference to tacky applies to what I have seen in various threads on the internet, and is not directed at anyone in particular. The internet being what it is, an open forum, means that one can often see situations where the blind are leading the blind. Having said that, I think the standard on the greybike forum is quite high. As for 'outstanding', no harm giving praise where it is deserved. On to the wire question. You did not mention anything about loads. I am no expert in these matters. I just had access to military spec wire at one time so I used it and experimented a bit with cable sizes. I am just interested to know if you can use a thinner section of wire for the same application.
Carb seal kits in viton & other parts
https://litetek.co
alexandervf
Bike owned: NC35
maelstrom wrote:Well that is why I should and do try to keep my opinions to myself, most of the time. My reference to tacky applies to what I have seen in various threads on the internet, and is not directed at anyone in particular. The internet being what it is, an open forum, means that one can often see situations where the blind are leading the blind. Having said that, I think the standard on the greybike forum is quite high. As for 'outstanding', no harm giving praise where it is deserved. On to the wire question. You did not mention anything about loads. I am no expert in these matters. I just had access to military spec wire at one time so I used it and experimented a bit with cable sizes. I am just interested to know if you can use a thinner section of wire for the same application.
Forgive me then, I misunderstood. Not knowing most of your languages expressions can get someone like me in a difficult position (Like now).
Due to the fact that we are all behind a keyboard, someone can misinterpret words and intentions.Sorry my mistake.
No you SHOULD speak your mind weather its a bad or a good comment. Just "give a little room for explaining" if someone is not familiar with certain expressions.
Feel free to ask anything that i can be of any help :peace:
alexandervf
Bike owned: NC35
maelstrom wrote: I am just interested to know if you can use a thinner section of wire for the same application.
To answer your question about these wires. From my knowledge these wires might give you a little room for "error", when i say error i mean that instead of using 18awg wire you can use 20awg wire and that's it (and it always depends on the application), no more no less. This example applies only for this wire sizes.
The general rule (and what everyone should follow) is what tolerances are given by the manufacturer of the certain wire. Different wires have different tolerances. One should ALWAYS check before proceeding.
Now, what i did, was to replace each honda wire with the exact size of teflon wire.
In one case, (this case was the cdi wires) the original wires where a little bit thicker than the wire available.So, i used 20awg rather than lets say 19awg that was the original.
Keep in mind that where there are high loads the thicker ,the better.
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
Nicely done. This makes me want to make a new harness for my track bike...
Maelstrom
Post by Maelstrom »
@ alexandervf
no apology necessary but thanks anyway
Just trying to get a handle on voltage drop with Spec 55
using http://www.simpsondonald.co.uk/download ... ndstra.pdf for resistance values and this formula
Voltage Drop = Amps * (2 * Wire Length * Specific Resistance)
assume
12 volts
5 amp draw
1 metre of 18 gauge (20.5 ohms per km)
= Voltage Drop of 0.205 volts
Is that anything like correct?
One more question. Did you consider using relays for the heavily loaded circuits?
https://litetek.co
alexandervf
Bike owned: NC35
maelstrom wrote: Is that anything like correct?
I think you should have a drop of 0.18 volts. (But it will always depend on conditions and application)
Yes i did use relays for my high and low beams.
Great work Alexander - excellent!
I also have a few spools of wire and a bag of connectors...but never got round to it.
JZH
Bike owned: RSCBRRVFVFRST
Post by JZH »
alexandervf wrote:
JZH wrote:Or the infamous red connector housing for the main fuse/starter solenoid.
Hey JZH,
I just found the on-line shop i bought this connector. http://www.dataspares.com/acatalog/Connectors_.html
is the shop. Ask andrew about a connector they used to stock by the code "C219".
Hope you can find it.
Thanks. As that connector is now not showing up on their Web site, I think it probably did "go extinct"! I have a couple of spare wiring looms for various Hondas (most used the same connectors), though, so I'll be fine. It would have been nice to be able to buy new, though. :cry:
Ciao,
JZH
So.Cal., USA/Hong Kong SAR, PRC
http://www.vsource.org
royster81
Post by royster81 »
So how many people now want a new wiring loom/harness for there 400?
