K Model Fork - Damper Rod Valve size?
On a recent fork overhaul me and viper61 noticed that my damper rods have some light grinding on both, i measured the 4 holes diameters and there 8mm, i assume the grinding was probably to remove the burrs from drilling.
What size are the stock damper rod hole dia's
Rick
Rick
Re: K Model Fork - Damper Rod Valve size?
18views and no reply, surely someone must have a damper rod spare to measure for me?
Think ive got some RVF ones in the garage, same size as the VFR internally aint they? can measure them if you like mate.
6mm on the RVF ones mate
- lukemillar
Yeah - I don't have any spares, but I'm pretty sure mine were 6mm before I drilled them last year.
What does drilling them out do?
- royster81
Someone drilled and welded up two of mine and the felt firmer but Graeme France rebuilt them with 2nd hand quality replacements and they feel fantastic, maybe not as firm but better over bumps and generally better on the road.
I knew what wanted Ricky buy couldnt help.
Revalveing effect, meaning the oil can squeeze through quicker, so like a twat knowing this now I should have gone for a little heavier oil, ive just ordered 10w silkolene but was contemplating 15w as i wasnt keen on its compression damping rate.Drunkn Munky wrote:What does drilling them out do?
TWAT!
Wanted: NC30 K Model - Damping Rods......?
Send me a pic mate, if there the same as what i have here you can have em.
