3tj with zxr400 forks
leadbasher
Has anyone tried fitting zxr400 forks to a 3tj, only my forks are pitted need new seals and I weigh 17st with leathers on, so if i am going to spend some money on my forks, I might try fitting these instead?
zimm
- Bike owned: some ZXR400's, ty175, mz ts125
Re: 3tj with zxr400 forks
dunno if they'll fit but they're good forks.. H model forks are longer and the caliper mounts positioned to suit 300mm discs while L model's are shorter and caliper mounts suit 310mm discs.
leadbasher
thanks for that
It's been done but really you need a front end: bars; forks; triple claps, wheel, discs and calipers.
Get your steering stem pressed into the tripple clamps, then you can drop the whole lot in. I don't know the lengths of the kwak forks but you may have to drop them in the clamps to get the geometry back to standard.
Oh - there's a pair of SP forks in the for sale section ... they'll drop straight in of course
spannerman
if wanting to use 52mm usd forks then you can use the triple clamps from an rgv these use the same bearing size an they fit without any modifications to the clamp or frame
hope this helps
hope this helps
leadbasher
I am going to start with a pair of L forks and yokes then take it from there thanks for the help
