The Exhaust Thread
Re: The Exhaust Thread
Jas is our man with his ear to the ground in Holland - AKA Micpec
Guru and Ethos addict
- micpec
I am sort of expert on this one....and bingo!Cammo wrote:I'm no expert but it looks very similar to a laser mild steel system that I used to own.reverse cylinder jim wrote:Can anyone tell me what make this mild steel half system is please. Came to me with no end can.
- micpec
A very early (old) type Ethos system. Bends not very "smooth" compared to the later types they have made. But the necessary Y-piece will be difficult to source these days in the correct (old) type. Might as well find someone who can fabricate one to your specs/needs.tomski wrote:New system acquired!
I suspect it's an ethos system missing the final 'Y Piece' and end can.
Can any of you marvellous bunch confirm or quash my suspicion?
- micpec
Thanks guys, including Tony and Kris..CMSMJ1 wrote:Jas is our man with his ear to the ground in Holland - AKA Micpec![]()
(been off for a while due to work commitments....very very very very very very busy these days
tomski
Cheers Jas,
I was hoping I might be lucky with an 'off the shelf' stainless Y-Piece, then I'll see if I can get my TIGing up to scratch at work to fabricate the rest of the link
. We shall have to see!
- speedy231278
Having bought a few bits and pieces from you on eBay over the years, I find it rather amusing to see that at some point things went full circle and you acquired the former private plate from my NC35 when I got it from a woman in Harlow. I wasn't willing to shell out on it seeing as firstly I was borrowing the money from my parents to buy the bike, and secondly I decided that to me it was a little bit odd describing it as 'big' when the big one was the RC45. She wanted £1500 to keep it when I bought it, hopefully it didn't cost that much. I did see it up on eBay from time to time for that, but it never seemed to sell.....abrmoto wrote: MHP SP1 Twin Stack, a work of art, best finished systems I have used, but again not cheap.
Hiperform 2nd generation full system
Not the easiest system to fit but ive had worse, rear headers are just about accessable with a good knuckle joint and the shock removed, a spring fitment to the headers like the HRC setup would have been a better idea.
Its barely done 100 miles and is already turning a nice colour and although the welds are not as nicely finished off as say ETHOS and TSR it has a works type look to it which i like.
Can isnt pictured but is a brushed alloy large bore affair and is loud!
marcus57
Just removed my full so called full micron system and it was a night mare , probably didnt help that the only bits i removed was the body work , system is in 8 sections minus the end can .
Will get some pics up for id'ing in a bit.
marcus57
Pics to go with the above
As can be seen in the last pics its marked nc30 ss but no maker , any ideas on make?
hunter
Yep defo Micron,Same as this one.
If you think you had peoblems taking it off,wait till you try putting it back on.
