advice spark plugs and chain sprocket set
wedge
come on peeps....whats the best spark plugs for 3tj??? and chain sprocket set...time to give the wee bike a major service.
Re: advice spark plugs and chain sprocket set
I just use NGK CR8 EK it's a copper core plug but with twin electrodes although the standard CR8E is fine. The FZR isn't to hard on it's plugs, my Bimota will lunch them in no time.
I just go to BandC Express for chain and sprokets. I have a 520 conversion O'ring chain.
wedge
what tooth are you running front and rear???..i hear if you go for the 520 you may have to change the number of teeth.
Dunno - BandC did the calc and supplied a kit, it runs just under stamdard
Taggyd
14/46 i think give about the same ratio as standard.
- Hogdigerdy Dog
Taggy wrote:14/46 i think give about the same ratio as standard.
i run 15/43, which amounts to about the same and use renthol rear but JT front sprocket, just be aware the renthol front has a smaller boss so you may need to space it, which is why i ended up with a JT front cos it fit's spot on
as for the chain i got a 520 pitch gold O ring chain (120 links) from dirt bike express on the bay for £54 delivered, and just cut it down from 120 to 103 links simples
It's true about the front sprocket - I had my chain fitted because it needed to be done and I couldn't find a riveter, they changed the supplied sprocket for a different one.
rustys
Any one tried the "IRIDIUM" spark plugs for the FZR 3TJ.
Russell
Russell
I have done but there's no desernable difference between them and standard plugs. I use the twin electrode NGK in both the FZR and the Bimota ... the Bimota used to eat irridium plugs but it's fine on the twin electrode type
rustys
Thanks, evilchicken
