rounded off bolt head
bullitt
Bike owned: vfr400 nc21
Post by bullitt » Sun Aug 12, 2012 3:12 pm
hi guys
one off my lower engine mounting bolts head has rounded off
its the last one to loosen to drop engine on my nc21 to put new collector
box on
tryed everything
mole grips pro socket impact socket any ideas
cheers
bikemonkey
Re: rounded off bolt head
Post by bikemonkey » Sun Aug 12, 2012 4:54 pm
Tried heat and hitting it?
lizard821000
Post by lizard821000 » Sun Aug 12, 2012 6:52 pm
+1
heat it up, then spray penitrating fluid on it, then hit it.
thunderace
Bike owned: R6, YZF600R
Post by thunderace » Sun Aug 12, 2012 7:41 pm
Centre punch the head then drill it off.
bullitt
Post by bullitt » Sun Aug 12, 2012 9:07 pm
cheers guys will give this a go during the week
i"ve been told about these easy out sockets anyone used them
thanks again
scotjell
Regular Member
Bike owned: VFR400 NC30x2
Post by scotjell » Mon Aug 13, 2012 10:10 pm
Also as it's the last bolt it may also help to support the weight as this will also put load on the bolt which will make it tighter/harder to move. Get some plus gas penatron anything like that. What size head is it could you go for an imperial size? or dremmel some flats on it is a possibility.
