Boiling over?
- Bike owned: VFR400 NC30x2
Re: Boiling over?
You've lost me now??
- Bike owned: Ducati 749S,BMW F800S,XBR500
Re: Boiling over?
I dont think a sticker kit is going to help here i think a new rad cap is first priority and a check on the fan switch is a must. I personaly would also put a manual fan switch in. I did a post on how to do that its really simple, just run a wire from the fan sensor single wire through the switch to earth.I have one which i use on trackdays when its hot.
Dave
Dave
Re: Boiling over?
fan switch is not fixing the problem though..
I don't have a rad fan fitted and I can only say that I have had to stop the bike and let it cool down probably 4 or 5 times in as many years. The bikes can cool themselves nicely if all is well.
Re: Boiling over?
It is if the bike is overheating and the fan isnt cutting in, and you are sat in the middle of nowhere 200 miles from home.
Re: Boiling over?
Post edited lmfao.........note to one self, re-check once copied and pasted
Re: Boiling over?
silver1956 wrote:fan switch is not fixing the problem though..
If the bike is overheating in spite of the fan then what use is the fan?
I don't use a fan, my bike does not overheat...
Re: Boiling over?
CSMJ1 says we dont need fans now, so might as well throw it in the bin.
I shalnt bother with this site anymore as i just get shot down with every suggestion.
Re: Boiling over?
silver1956 wrote:CSMJ1 says we dont need fans now, so might as well throw it in the bin.
LOL -come on man..chill.
Just pointing out that you are putting a plaster on a festering wound. The problem is that it overheats regardless of fan being on or not. I am merely pointing out that they don't usually overheat with a fan not fitted so that the problem is more fundamental that a fan.
I have a fan if you want one..in fact, it is stuck onto a rad I am never going to use too..
Re: Boiling over?
CMSMJ1 just to ask are you selling the lower rad as I'm after one don't need the fan though
Re: Boiling over?
@ Scot - can do mate
