NC23 Sidelight bulb where to find
- Bike owned: NC30, R1, CB250RS, FZR400
Hi all,
Just about to finally get my NC23 MOT'd and on the road and found that one of the sidelight bulbs is blown. I am struggling to find one anywhere on the internet! Does anybody know where to get them?
Currently the lights work as follows:
switch at P - Left light sidelight bulb on Right light Nothing
switch at H - Left light sidelight on Right headlight on half bright
Full Beam - Both lights full brightness
Thanks for any advice
Re: NC23 Sidelight bulb where to find
dunno for sure.. confirm anyone?
if they are the same as the NC29 one?
5mm wedge bulb which means you can change them for LED bulbs instead..
- petrolhead19
cheers, ill get some of them fitted! Ive been restoring the bike over the past few months and its almost ready, the last thing im struggling with is to work out where the horn should be mounted??
On my Tri-arm I'm pretty sure it's in between the forks underneath the bottom yoke.willpisme wrote:where the horn should be mounted??
EDIT: For example http://www.cmsnl.com/honda-cbr400rrj-nc ... ml#results REF: Number 1.
You'll end up using CMSNL a lot, I know I have done.
- petrolhead19
yup as rob says the horn is located in between the forks and the bolt to mount it will be on the bottom yoke underneath
Adam
Adam
Thanks a lot guys, got it all sorted now cheers! Soon as i have the pillion foot rests fitted the bike will be complete wooo!
Which ones and are they any better than the standard bulbs - distance of light etc -petrolhead19 wrote:i just use T5 fitment bulbs they fit alright
http://www.crazyleds.co.uk/T5-286-LED/
i cant stand riding mine at night anymore as the standard lights arent v bright are they, so interested in swapping over !
Do the bulb holders/wiring need any mods?
- petrolhead19
The ones i had wasn't very bright but im thinking of trying these ones out
http://www.crazyleds.co.uk/1-x-Ultra-Qu ... 5-286.html
Dont need any mod and they fit straight into the sidelight holders :D
ok great, might try these.
