NC35 Oil drain bolt size
dengus
Post by dengus »
Hi! Could anyone tell me the size and pich of the NC35 oil drain bolt?
I live in Spain and now is bloody hot and i want to fit an oil temperature sensor, because the water temp is always very hi and fan is most of the time on so i want to monitor the oil temp. Also the water temp is a dial and dosent say the temp in numbers so i want to have a more accurate reading.
What should be a normal working temp? Oil and water??
Thanks in advance
speedy231278
Re: NC35 Oil drain bolt size
Post by speedy231278 »
According to the microfiche it's 12mm, but doesn't give a length or pitch. I guess it would be nothing out of the ordinary. I don't know the figures on water or oil, but surely unless the gauge is buried in the red, there's nothing to worry about?
porndoguk
Post by porndoguk »
if its the same as the NC30 its a M12/12mm x 1.5pitch, 14mm thread length, 17mm Hex Head
dengus
Post by dengus »
