Gallery
JAMESVFR400
Re: Gallery
Post by JAMESVFR400 »
Current ride - had it since xmas, first bike in 2 years since the write off of my RC replica.
old ride
older ride
old pride and joy
first ever ride
JC120
Re: Gallery
Post by JC120 »
Here's mine. The red white and blue is getting new fairings. The red and black is all stock except for the wind screen.
Starr
Gallery
Post by Starr »
Heres mine. (:
webby16
Bike owned: vfr 400 nc30
Re: Gallery
Post by webby16 »
hi wingzero!
im really interested in the k conversion kits but no one seems to have any experiences with them. i have done my research and i knew about some small problems like the dial and tacho bracket needed cut down but is there any other problems that i will encounter? any help will be greatly appreciated
thanks webby16
WINGZERO619
Bike owned: 1996 RVF400
Re: Gallery
Post by WINGZERO619 »
webby16 wrote:hi wingzero!
thanks webby16
Hi there webby16. If you're interested in getting the same kit like me, then I'll warn you that the subframe is not made to bolt your electronics down. You basically have to stuff everything under your seat. Also, you'll have to extend wires out to the tail to wire up your tail lamps. Front meter stay needs to be modified a bit. The metal is soft enough where you can use a dremel tool to cut out the space needed to mount to the neck of the frame. Take your time putting on your kit if you decide to get it because the fiber glass is thinner than Tyga's kits. Hope this helps.
-WZ619
mbikerdav
Re: Gallery
Post by mbikerdav »
http://www.flickr.com/photos/81235465@N08/7438689232/
Mines on the right, the one on the left belongs to another forum member here, a good friend of mine (steve85)
EDD16V
Re: Gallery
Post by EDD16V »
Is it normal to have your forks that far through the yokes on a track bike or are the forks off a different bike?
Re: Gallery
Lol you could take your eye out on them. They look like fire storm forks.
Cammo
Re: Gallery
Post by Cammo »
Drunkn Munky wrote:They look like fire storm forks.
They are indeed:
viewtopic.php?f=22&t=36333&p=262952#p262952
AndyJak
Bike owned: ZXR400, NC30, ZX10-R
Re: Gallery
Post by AndyJak »
Here is mine:
Full TYGA bodywork, full TYGA exhaust system.
