Six Hundred and Sixty
Re: Six Hundred and Sixty
Post by Evilchicken0 »
I think they're the same, but here's a pic of my nuts :grin:
Would you have a pic of the cam caps ??? Do the arrows on the E1/I1 and E2/I2 point to the spark plugs ???
Alex.
Post by Alex. »
I know I have some of those nuts, but the engine came disassembled. I can let you know come winter, when I start my conversion.... :grin:
Alex.
bastardos
Anyway, here's that crankcase seal, the internal dia shown is the crank dimension and the 3HE seals on the rear or engine interior side.
Alex.
Post by Alex. »
Evilchicken0 wrote:I think they're the same, but here's a pic of my nuts :grin:
And here are my nuts, it's only fair... :o
Alex.
Nice nuts mate :o
Alex.
Post by Alex. »
Evilchicken0 wrote:Nice nuts mate :o
That's all the more worrying coming from you, dear!
Alex.
Maelstrom
Bike owned: MC22, 3TJ1
Post by Maelstrom »
EC, regards your seal. That drawing is what you require? I am assuming the lip has a corresponding recess in the crankcases, so you must fit the seal onto the crank before assembling the cases?
Carb seal kits in viton & other parts
https://litetek.co
Yup - the seal drawn is the outside dia from the original seal and the inner dia is from the crank. The 3HE "seals" on the rear (the engine side).
I used the Frankenseal when I assembled the cases, but I drew that up to help anybody who's going to stroke a 4JH after me, so if you can source them it would be useful.
Maelstrom
Post by Maelstrom »
Like the one in this thread
http://www.fzrarchives.com/ipb/lofivers ... 56726.html
It says CR 26x40x8 HMSA7 R on the box.
I did not read all of this thread but it looks close to what you need.
https://litetek.co
That looks right - the seal numbers match up with the drawing too (although Mine is 10 thick, probably from combining the two seals)
I found the missing head nut, But I'm a bit low today. The cam chain is caught up with the bottom of the front chain guide and I can't get the fucking guide out. I took the sum off, I'd only tagged it on with 2 bolts. I couldn't get to the chain though ... and I found this
Any ideas :cry:
