Fzr 400 sleeper
- Acid
- Bike owned: Rs125 Nc30 Cr500 Sm
Fzr 400 sleeper
o.k pictures say lots so here is some  this is my friends Fzr he has nearly finished.
what do you lot think so far want can you notice about it
Re: Fzr 400 sleeper
Looks just like a ThunderAce
Looks like a bit of works gone into it - I'd loose the grabrail off the back though.
Back light is a 4DX style, not sure if the forks are SP or not
Did he change the engine - I notice a liquid clutch
- Acid
Re: Fzr 400 sleeper
Of all the Fzr owners i expect you Boris to get it straight away
your on the right trail tho !!!
				rockTJ
- Bike owned: GSX650F FZR250x2 RSV RG80
Re: Fzr 400 sleeper
I'd say YZF750 looking at where the alternator is situated??  The Thundercat still has it's genny on the end of the crank doesnt it?
Chris
						Chris
- Acid
Re: Fzr 400 sleeper
yes thundercat gen is at the other end
its not a Yzf750 tho but getting warmer !!!
Clue is in the picture tho !!!
Re: Fzr 400 sleeper
Going to be an old exup thou then eh?  Cool...
- Acid
Re: Fzr 400 sleeper
Ten points to Mark :D
It the engine was bored and tinkered with and came from the thunderace next to it.
it makes 157 ish bhp, R1 GSXR zx10 blade baiting power !!!
In a 400 frame, the fairing fits fine too.
Nice sleeper :D
Nice sleeper :D
Re: Fzr 400 sleeper
I bet that is a mental bastard...
How is it fitted? More pics please Karlos my good man!!
Re: Fzr 400 sleeper
You have to shave the frame to get the carbs and the clutch in. The engine is heavy too, the headraces won't take the beating
				rockTJ
Re: Fzr 400 sleeper
Rock on that man.  The lower steering head bearings on the 3TJ, which take most of the weight, are the same size as the 4XV R1 so unless you are living on the back wheel 24/7 I bet they'd be ok.  Might be worth fitting a longer swinger tho, to help out scrubbing the front tyre now and again
Chris
 Chris
