headlight covers, round and silhouette shapes.
- royster81
Re: headlight covers, round and silhouette shapes.
tonight i had a go to see how easy it was going to be to try and bend these to suit the different nose cone shapes,but because it was my first try i decided not to practice on my silhouette but i tried it on a standard nose cone i had at hand
as it was a trial attempt i haven't drilled the holes in either the cover or the nose but i have used a bit of electrical tape to hold them on to give you a basic idea.
- Smev
- Bike owned: NC30 of course
Looks good to me - with the proper screws it'd fit pretty well :-)
Mister Donut Rep NC30
you could even use velcro patches, some domed allen bolt or clear number plate bolts would finish it off, are they flexible
- Deviant400
how are you creating the bend in them , using a little heat ?
viewtopic.php?f=62&t=27307
He bends them with magic.......Deviant400 wrote:how are you creating the bend in them , using a little heat ?
- Deviant400
izzzy wizzzy lets get busy !!! i got to try make one for my suzuka cover , but its got quite a curve to it and im trying to figure out the best way to go about it and tappin it with a black n white stick with a sooty puppet aint gunna do it
might give uri geller a call
Work out the melting and bending point of the material your using it maybe posible to use a boiling water, or if not the oven at 130 for a few mins if that dont work go to 140 and so on i think perspex bends at 130 and melts at 150ishDeviant400 wrote:izzzy wizzzy lets get busy !!! i got to try make one for my suzuka cover , but its got quite a curve to it and im trying to figure out the best way to go about it and tappin it with a black n white stick with a sooty puppet aint gunna do it
Rick
- Sam-NI
- Bike owned: '89 VFR400
Hi guys, haven't been on here in a couple of days, too busy getting my bike actually running! (cheers Gareth!)
At the moment, those where handmade, but hopefully will get them coded into the CNC machine soon. As for colours, i'm not too sure what I have at the moment, but I should be able to offer a range of transparent, and block colours. I'm going to work with what I have, don't fancy ordering it a load of material, and it not being used, but if there's enough demand, i'll think about it.
Cheers for the interest so far! I could be busy with real work for the next few weeks, but i'll see how I go. By July I should be able to start on them properly, but hopefully before!
marcus57
Any idea of cost ?
- hannakournikova
Sour grapes much?ibby4585 wrote:hannakournikova wrote:i think between me and Rhory we have 3 silhouette nose cones if Sam needs them :)
Yeah but you wont sell them they will just rot in your garage with all the other stuff!
And Rhory's is decent!
