Rear wheel seized onto hub
simo268
- One Hit Wonder
- Bike owned: Ninja, Speed 4
Hi
Im trying to remove my rear wheel however it is stuck on fast to the hub. Any ideas on how I can remove the wheel?
Danny
Danny
lizard821000
Re: Rear wheel seized onto hub
rubber mallet, take it youv undone every thing.....
few taps at 3,6,9,12 should do it.
hardnutdvd
- Bike owned: RVF400 NC35
taps..? more like fuckin great whacks!!
brute force mate, they can be a real pain in the ass to get off
- Smev
- Bike owned: NC30 of course
A bit of wd40 onto the mating faces or if you can get to them on the spigots.
Take care not to get any on the disc or pads!!!
Mister Donut Rep NC30
scooble
mine was stuck on good and proper and wouldn't come off with leverage or a 'hammer'. In the end I got a large bearing puller and machined up a reaction block for the center. I had to REALLY wind it in before it finally came off.
Gave it a good clean up with wet/dry and assembled with copper slip
- CRM
if the wheels been painted or powder coated it is essential the inside edge is cleaned up before fitting or it will be stuck good style.
get a mate to help and as has been said before block of wood, lump hammer and keep rotating it when hitting
BIKERMANLALLY
- Bike owned: VFR400 NC30(1991)
Or failing that get the garage to do it. I found out mine was like that a couple of years ago when it had a puncture&they replaced the tyre.
fixer
- Bike owned: nc30/bsab25
Hi go to page 5 of my posts and make up said tool .easy to make.before you refit wheel clean mating surfaces and apply copperslip,jobs a good un.
F I X E R
