Streetfighterz1000
Post
by Streetfighterz1000 » Wed Jun 06, 2012 8:01 pm
Hello
Took the Nc30 track bike for a quick test ride today, starts up and runs fine, revs cleanly up until 5-6000rpm then feels like its being restricted or boging down and is an effort to rev any higher, any ideas would be much appreciated.
nazzurro_19
- Bike owned: Honda NC30
Post
by nazzurro_19 » Wed Jun 06, 2012 8:10 pm
is it maybe in the "limp home mode" ?
slowsport
- Bike owned: NC35
Post
by slowsport » Wed Jun 06, 2012 8:36 pm
could it be perhaps the vacuum pipe that goes to the fuel tap? perished or dis connected?
kevprojex
- Bike owned: ktm200exc gsxr400gk71b sv650
Post
by kevprojex » Wed Jun 06, 2012 10:38 pm
Have you taken the speedo off ? , if so you will need to add 2.2k resistor into the orange/blue wire to + feed.
hannakournikova
Post
by hannakournikova » Wed Jun 06, 2012 10:47 pm
So it doesn't rev past 5-6 or just bigs down?
If the first - then check your carbs are cleaned, balanced and jetted.
If the later then there is an electrical prob. Usually is something to do with derestrictor. Alarm bells ring when it's a track bike - has the speedo been removed?
Cammo
Post
by Cammo » Thu Jun 07, 2012 1:32 am
hannakournikova wrote:Alarm bells ring when it's a track bike - has the speedo been removed?
+1
It's common to see peeps remove (or unplug) the speedo unit without realising the bike will then go into limp home mode (cuts spark to 2 cylinders after 5000 rpm). This can also occur if the blue/orange cdi wire is cut/broken.
If this is the problem it's an easy fix, just do the derestrictor mod - there's a guide in the document library:
http://www.400greybike.com/docs.htm
Streetfighterz1000
Post
by Streetfighterz1000 » Fri Jun 08, 2012 1:54 pm
Yes speedo was removed, didnt know about it messing with the rpm, will refit speedo and retry, thanks
Streetfighterz1000
Post
by Streetfighterz1000 » Fri Jun 08, 2012 10:26 pm
All sorted now, fitted the speedo back on and worked straight off, easy when you know how!!!
