left hand switch controls
well i had trouble with the push button beam switch on my nc29 1994 model cbr but that got fixed but the low beams still aint working i bought a 90-93 switch controls but the mechanic said it wouldn fit so is there any fix for the low beams or does anyone have a working one from a 94 model thanks
- Davez29
- Bike owned: NC29 forever
Re: left hand switch controls
You might find an nc35 switch will fit, not sure if its the same connections but it is the same switch arrangement, maybe even some other vfr/cbr from 94/95 will be the same . If low is not working maybe you got the contacts wrong on fitting?
no it wasn working at all and the main thing is the connections i just need a straight swap i dont want to start fiddling with loadsa wires that i dont have a clue about
- Davez29
I have a RVF400 switch (not for sale) but never checked if the plugs are the same. here is a picture of the main plugs, maybe you can check. It would give you more options on ebay if it is the same.
its alright lads i got one of graeme thanks anyways
- Bike owned: cbr400rrj
i had same issue with my low beams... opened switch to find contacts not touch due to wear and age. inserted peice of plastic about 3 mm thick between switch and side and away worked my lights!!!! 5 mins maxscottser32 wrote:well i had trouble with the push button beam switch on my nc29 1994 model cbr but that got fixed but the low beams still aint working i bought a 90-93 switch controls but the mechanic said it wouldn fit so is there any fix for the low beams or does anyone have a working one from a 94 model thanks
