Is this HRC CDI or what ?
PARUS
Found in colin martin's collection.
davidsimon10
Re: Is this HRC CDI or what ?
ITS A DYNA 2000 UNIT . it has adustable rpm in 500 rpm stages and advance and retard curves can be programmed !want one
zimm
- Bike owned: some ZXR400's, ty175, mz ts125
davidsimon10 wrote:ITS A DYNA 2000 UNIT . it has adustable rpm in 500 rpm stages and advance and retard curves can be programmed !want one
im about to put in an order for half a dozen programmable ignitech cdi's if you want one ?
programmable advance
programmable rev limiter
mapping for tps
shift light
clutch/stand cutouts
should come in under £100 per unit delivered (bout 75 - 80 hopefully)
see topic
http://www.400greybike.cc/newforum/view ... di&start=0" onclick="window.open(this.href);return false;
PARUS
I'm with in case you resend me to Ukraine. Or maybe better to ask them directly. Will it do the same as PowerCommander ?
PARUS
Detaile descriptions of this: http://www.ignitech.cz/english/honda_tc ... tci_en.pdfzimm wrote:davidsimon10 wrote:ITS A DYNA 2000 UNIT . it has adustable rpm in 500 rpm stages and advance and retard curves can be programmed !want one
mapping for tps
shift light
see topic
cbr racer
i'll ake one of you get them in....do they need the nc23 casing for the pickup???
