Nc30 ignition switch
- V4beermonster
- Bike owned: Vfr400,gt750,vfr400/750cc
Can anyone confirm the order ther 3 wires sit in the block connector bought an ignition switch but black block connector is not fitted. A good photo or diagram would be great cheers phil
- Bike owned: '92 nc30
Re: Nc30 ignition switch
phil, if you get stuck i have the old wiring loom part from my switch which got broken by vandals, there is no ignition switch at the one end just wires, but the end with the block connector is still there and all wires are where they are meant to be, ill pop it in the post if you want it mate.
let me know..
chris
let me know..
chris
- V4beermonster
Hey I have the connector it just the wires are not in it just need to know what order they are cheers pal
Surely you can just match them up using the plug on the loom that it plugs into?
- V4beermonster
Have not taken fairing off bike yet just wanted to get all sorted on the bench and then fit
