Can I come back???
viper_biker
Re: Can I come back???
Good enough reason if you ask me.Martin wrote:I think I've pretty much given up on mine until I have a garage...........
- spooky
- Bike owned: nc24
Just use the kitchen or back room like a real biker, lol.
- spooky
- Bike owned: nc24
4 years gareth, sheez time flies don't it.
- micpec
here is some smiley girl on this forum to cheer you up...
Welcome back, Gareth!
viper_biker
Well, we're back on a roll again. I've collected a lot of the necessary bits to have myself a bike built at some point this year. OK, so I started on the motor tonight. Got the cam covers off and checked the valve clearances. 10 ports out, 6 were fine. Most were tight apart from 1 that was extremely loose.
Shabby looking, but hopefully a power plant,
Easy to do out of the bike,
Cams off,
First figures,
All worked out and now need some new shims,
Hopefully more to update tomorrow.
Cams off,
First figures,
viper_biker
Well, looks like the Fireblade shock isn't gonna fit into the 400. It's too tall. Only alternative is it lengthen the dog-bones so that the spring doesn't foul the swingarm.
Touching,
Where it needs to be at,
So that it'll sit like this,
Touching,
- mo haggs
- Bike owned: bikeless
Get some made up.
viper_biker
A good bit of progress tonight. Got all the valve clearances sorted and got the frame on and swingarm in. Slow progrees but getting there, Monday will see me fettle the carbs a bit and give them a good clean as well as fit the new bushes and seal and re-build the forks.
- mo haggs
looking good pal.
viper_biker
Forks now built with new bushes, new seals and fresh oil and out on loan to Royster for as long as he needs them. Loom is in along with CDI and M-Max box. Got some more pieces coming to keep the build going.
