3EN1 Pads & Seals ........
fredjee
Hello .....
Now looking for fork seals & brake pads for my FZR1-Z Project ....
Its fitted with 1WG 3EN1 running gear from 1988 ....
Will this stuff fit as the 3EN1's a Grey Import ?
Thanks ...
Fred.
Stuff : ......
http://cgi.ebay.co.uk/Yamaha-FZR400-SC- ... 286.c0.m14
http://cgi.ebay.co.uk/Front-HH-Brake-Pa ... .m20.l1116
Thanks ...
Fred.
Stuff : ......
Taggyd
Re: 3EN1 Pads & Seals ........
the fork seals should be fine, its what i got for mine! the brake pads can be a bit of a lottery, there seem to be a few different styles fitted to em! if you've got a pic i can tell you if its same as mine and give you the part number for the brake pads.
fredjee
Hi Taggy,
Thanks for the offer of help M8 .....
Attached should be a picture of the Sunimoto calliper ...
Fred.
Fred.
Taggyd
aye they look like mine!!! both pistons the same size! i used pads with the number fa123 thats for ebc HH but if you give that to a parts place they'll be able to find the equivalent other makes from their books. try it as a search in ebay and you'll see what i mean!
hope it helps!
ps the rear should be an fa104
hope it helps!
fredjee
Thanks very much M8 for all your helpTaggy wrote:aye they look like mine!!! both pistons the same size! i used pads with the number fa123 thats for ebc HH but if you give that to a parts place they'll be able to find the equivalent other makes from their books. try it as a search in ebay and you'll see what i mean!
hope it helps!
Fred.
