NC35 speedo reset knob removal
fastdruid
Er how?
I'm trying to replace the clock back but I can't get the speedo knob off.
Is it just a pull off? I've tried pulling it but am I not using enough force or is there some trick to remove it?
Druid
Druid
- RVFHooligan
Re: NC35 speedo reset knob removal
There is a very,very,very tiny phillips head screw on the inside of the knob. Look down that little hole in the center.
fastdruid
I looked originally and it was yellow, I scraped a bit and it was still yellow and pretty solid looking so I left it alone.
I've just scraped lots more and finally came across the head of a screw, except I don't have a screwdriver fine and long enough to get down that far.
Oh well I shall have to buy some more tools! :D
Looks like they put a blob of resin down there which is why I didn't spot the screw in the first place.
Druid
Druid
That little bastard screw can be a right pain, especially when you drop it into the V of the engine!!
I use These
For £4 delivered you can't really go wrong :)
I use These
