NC30 17” rear wheel conversion Help
california kid
Post by california kid »
Im sorry I don’t know if I’m in the right forum, I’m currently converting my rear wheel to 17” rim but confused what needs to be done adout the ride height. Question ,1 will it even make a difference? 2, I have been reading somewhere if you upgrade to a 17” you need to change the “Dog Bone” from an NC35?
Please se attached photo if that’s what the fore mention part is? And how do I go about changing it?
http://i640.photobucket.com/albums/uu12 ... Bone-1.jpg
Thanks everyone!
Cammo
Re: NC30 17” rear wheel conversion Help
Post by Cammo »
Hiya mate,
When you change to a 17" rear from the original 18" the rear will sit 1" lower which is not great for the bike's geometry given they steer fairly slowly as standard. Best to restore it to the original ride height. You can fit the lower linkage from an rvf, or modify the original vfr linkage, the latter also helps to firm up the shock which is worth it if you use a standard shock.
Good thread here for more info:
viewtopic.php?f=24&t=5346&p=37396&hilit=dogbone#p37396
You'll need to take the weight off the rear wheel to remove these parts. Some people use proper stands, I don't have any so I use a couple of car jacks and some bricks under the rearsets. :oops:
california kid
Thanks Cammo, was I on the right track that the NC35 bone would solve my problem? also was that the correct piece I need in the photo?
royster81
Post by royster81 »
No need to double post fella.
porndoguk
Post by porndoguk »
royster81 wrote:No need to double post fella.
:plus:
scooble
Post by scooble »
a 17" wheel has a radius of 8.5", a 18" wheel has a radius of 9"
9" - 8.5" = 0.5"
so how come a 17" conversion means that the bike sits 1" lower? - (I'm not that good at maths)
scooble wrote:a 17" wheel has a radius of 8.5", a 18" wheel has a radius of 9"
9" - 8.5" = 0.5"
You are right..
lalalandrus
Post by lalalandrus »
the nc-35 17" is narrower (3.5vs4.5) and the aspect ratio on the tire is 60 meaning you will have a 1"x.6 height difference IN ADDITION to the .5" diameter difference giving you a total of 1.1" typical
you can elminate this extra "tax" if you go with a VFR750 wheel which is the same width
hope this helps
Cammo
Post by Cammo »
lalalandrus wrote:the nc-35 17" is narrower (3.5vs4.5)
Both nc30 and nc35 rear wheels are 4.5" wide.
The vfr750 ('94 on) is 5.0" wide, earlier models were 5.5".
lalalandrus
yeah i misread the specs you are right, either way you can eliminate a .5" height difference if you go with a 5.5" wheel...
