ZXR 400 TO VFR 400 NC30 FORK CONVERSION
- superlite
- Bike owned: TLS, LB80 x 2
Re: ZXR 400 TO VFR 400 NC30 FORK CONVERSION
Agreed. But in my world an 'upgraded' battery is a smaller one! We may have different needs in mind though. RGVs are small and work well. If you want something bigger just measure it up and go for higher cold cranking amps.Neosophist wrote:Putting a bigger battery on may mask problems with your charging system (quite common on VFR's)
'Take it to the Back'
racesupplies
We got one from Varta,2 thirds the size,three times the cold cranking capacity.
- RickOliver
...and I do still have the headstock adaptors to fit ZXR400L yokes onto the NC30 frame.
Rick
Rick
lizard821000
350 quid! cant be right. ill check ricks price list.
- wangwang
RickOliver wrote:...and I do still have the headstock adaptors to fit ZXR400L yokes onto the NC30 frame.
Rick
How much are they and what do you get?
wang
hunter
Fork conversion kits (headstock adaptor & taper roller headraces) -
NC30 frame/ZXR400L forks £80
NC30 frame/NC35 forks £80
Thats what his priclist says.
lizard821000
iv got a set of zxr 400l forks up for sale soon if anyone is thinking about the conversion.
lizard821000
hunter wrote:Fork conversion kits (headstock adaptor & taper roller headraces) -
where did the 350 quid come from then!?
- wangwang
lizard821000 wrote:hunter wrote:Fork conversion kits (headstock adaptor & taper roller headraces) -
Think that might be a new set of custom yokes.
