What headlight bulbs are in an NC35? Cheap upgrades???
spadey99
Post by spadey99 »
Hi guys
I tried searching but cant find what bulbs are in a 35 as standard? Just wanted to buy some brighter ones off e bay.... What options do I have?
Steve
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: What headlight bulbs are in an NC35? Cheap upgrades???
Post by hardnutdvd »
Standards are 60/35w..
to upgrade and use 60/55's you need to do the low beam relay modification... found in the docs library
http://www.400greybike.com/docs.htm
the doc is called the vfr headlamp relay mod. there is also plenty of threads on here. use the advanced search in the v4 section.
by just putting 60/55 bulbs in without the mod, it will burn your left switchgear.
spadey99
Post by spadey99 »
Thanks for that, are they H4?????
hardnutdvd
Regular Member
H4..yes
