Tyre size for FZR rear wheel
				reverse cylinder jim
Hi ive bought what i think is a 3tj rrsp rear wheel to fit into my reverse cylinder Yam and wondered what the correct tyre size is to run? 150 or 160? Size is a 4.50 by 17".
Thanks James
						Thanks James
Re: Tyre size for FZR rear wheel
It's a 160 on the 3TJ
Many thanks for the info.
						- Kayla850
- Bike owned: Sunn Tzar S2
But it's a 150 on the 3XV which also has a 4.5 x 17" rear wheel.
www.projection-racing.com
www.pjcfasteners.com
				rockTJ
- Bike owned: GSX650F FZR250x2 RSV RG80
Damn, got a new 140/70 BT090 Pro in the shed I was hoping to use.  Too small I take it for the rear???
Got it for an FZR250 3LN which I sold before I fitted it.
Chris
Chris
- Hogdigerdy Dog
150 rear profile is standard across the tj rangeKayla850 wrote:But it's a 150 on the 3XV which also has a 4.5 x 17" rear wheel.
but most peeps run a 160 rear, only problem you may have is the chain guard but mine had been trimmed by previous owner, so no probs
- thunderace
- Bike owned: R6, YZF600R
If that had been an 18" I'd have had it off you for the FZRrockTJ wrote:Damn, got a new 140/70 BT090 Pro
Yamaha quote the size as a 160/60 17Hogdigerdy Dog wrote:150 rear profile is standard across the tj rangeKayla850 wrote:But it's a 150 on the 3XV which also has a 4.5 x 17" rear wheel.
Normally a 160 would be on a 5" rim and a 150 would be on a 4.5" the wider tyre is pinched which raises the back a little.
				rockTJ
£103 here inc delivery, use these people for all my odd size tyresthunderace wrote:If that had been an 18" I'd have had it off you for the FZRrockTJ wrote:Damn, got a new 140/70 BT090 Pro
http://ssl.delti.com/cgi-bin/rshop.pl?d ... =110&m_s=1
chris
cough ... supercorsa
