NC29 Fork upgrade & Fork Top replacement
RSVR
Post by RSVR » Fri Apr 06, 2012 11:10 pm
I've recently pick up a nice NC29, but the forks are rubbish and need fresh internals.
I have a new set of race tech springs from a SV650 is this recommended upgrade. The springs are just over an inch shorter then stock.
Additionally, anyone know if you can purchase fork tops????
Yakama
Re: NC29 Fork upgrade & Fork Top replacement
Post by Yakama » Fri Apr 06, 2012 11:38 pm
Not sure about SV springs but Graeme France sells racetech springs as an upgrade.
Not sure about replacement fork tops but would these fit:
http://tyga-performance.com/site/produc ... ts_id=1142
Gavin from Jap4performance may know
RSVR
Post by RSVR » Sat Apr 07, 2012 11:47 am
Will NC35 forks fit the 1992 CBR 400 obviously using the NC35 stem and yoke?????? :whistle:
RSVR
RSVR
Post by RSVR » Sat Apr 07, 2012 4:35 pm
Anyone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :whistle:
Post by Drunkn Munky » Sat Apr 07, 2012 4:40 pm
Yep they do fit mate, see this thread viewtopic.php?f=62&t=25508
RSVR
Post by RSVR » Sat Apr 07, 2012 5:16 pm
T,
Thanks buddy, did you get my PM regarding air box
tanuki
Post by tanuki » Sat Apr 07, 2012 5:40 pm
RSVR wrote:Cheers
RSVR
Not directly no you will have to transplant the stems if you want to do it properly.
Some people dont bother and only use one locking nut......
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti » Sun Apr 08, 2012 1:01 am
Use the SV650 springs if from a curvy, as the bikes are of very similar weight so should be fine, or at least not worse.
Wet weights (swift google only, no facts here)
nc29 - 182kg
curvy SV - 189kg
sharp SV - 198kg
You can use preload adjustable fork caps off many Hondas such as firestorms, some VFR750s, CBR600s, etc. Doesn't matter if they come with a damping adjuster that you don't need, you can chop that off on the inside no worries. These caps effectively take up about 1" more of spacer room or thereabout, so if you get these, not only will you have adjustable preload, you also (probably) won't need new spacers. So it's definitely worth a go if you can find a cheap set. Any adjustable cap off any 90's-ish honda 41mm forks "should" be fine.
This is what it looks like:
HTH.
cajun
Bike owned: MC22, NC29,NC35, 2 FZR400's
Post by cajun » Sun Apr 08, 2012 11:24 am
However if you have the newer 29 forks you will have to get F3 fork caps.
RSVR
Post by RSVR » Tue Apr 10, 2012 10:35 pm
Many Thanks chaps for the useful information. :peace:
Will fit the race tech sv springs, with fresh oil and see how they feel.
Regards
