Fuel tap issues
Fuel tap issues
Hi
My NC30 has never had the vacuum membrane in the fuel tap, and the tap leaks slightly when off. This means if the needle and seats ever fail to seal I am in trouble.
Any suggestions? Are new vacuum membranes available? Can the tap be serviced or new ones obtained. I feel its a ticking timebomb.
Re: Fuel tap issues
Rick Oliver sells fuel tap rebuild kits that includes the diaphram, could be a good option.
Re: Fuel tap issues
leaking tap sticking float valve probably the only way to kill an nc30 engine other than a silver bullet as i found out on my trackbike petrol in the oil not a good thing .
Re: Fuel tap issues
Thanks, will get hold of Rick now I know he sells rebuild kits, there are a few other parts I need too
- skinnydog0_0
- Bike owned: Penny Farthing
Re: Fuel tap issues
or get a dry brake connector for the fuel line
