Steering Lock weirdness on GK76a today
- Tonyj
- Bike owned: FZR400 3EN1 88, YZFR125.GK76a
Okay am I missing something but something i havent seen before happened today when applying the steering lock on my GK76a, the bleedin main beam came on
, wtf?
Is this a loose connection ?
edit lol had removed key from ignition haha oops
Tony
Tony
Armi400
- Bike owned: GSXR400RRSP/SRAD 600
Re: Steering Lock weirdness on GK76a today
That confuses me....I thought main beams stayed on!
- Tonyj
I had taken the key out of the ignition ( oops should have said so in first part of post) and checked there was no switch on just in case, then put key back in ignition moved it only just slightly back a touch and it went off...Some electrickery goin on methinks .
- Variablevalves suck
Have you got a park light lock? some bikes have the lock and then another park light + lock just passed that.
morris147
This is correct, engage the lock then turn it a little bit more and the park light comes on. I found out the hard way....Variablevalves suck wrote:Have you got a park light lock? some bikes have the lock and then another park light + lock just passed that.
- Tonyj
Phew.. I really thought i'd lost the plot yesterdaymorris147 wrote:This is correct, engage the lock then turn it a little bit more and the park light comes on. I found out the hard way....Variablevalves suck wrote:Have you got a park light lock? some bikes have the lock and then another park light + lock just passed that.
Morris147- Dont say it drained the battery mate? Nitemare
Thanks for the answer lads.
- Awynn
- Bike owned: GK73a, CB250, NS125R-K, CLR125
If it was that then it would only put the side light on and not "high beam" as you said.
