carb jetting
john21z
carb jetting
Post by john21z »
hi is the carb jetting guide by cammo relivent to a nc21zh :?: :grin:
Cammo
Re: carb jetting
Post by Cammo »
Everything aside from main jet size and needle codes is.
Both types of carbs are very similar.
john21z
Re: carb jetting
Post by john21z »
cheers for the reply cammo .
iv got to clean my carbs so i might as well do a bit of fetling while im at it.
Re: carb jetting
Post by Neosophist »
Don't drill the slides or shim the needles, you shouldn't need it.
john21z
Re: carb jetting
Post by john21z »
hi has any one got any tips about getting them back on?.
im gonna buy some new carb rubbers but i am unsure i will be able to get them back on
iv heard nightmare storys. even from good bike mechanics about wot a b*****d thay are to get back on.
ps any one know the setting heights for the flowt bowls :?: thats why im stripping them.
thar over fueling badly strong smell ov fuel from the exaust .
hope the weather sorts it self out ive got to do this job
outside on the drive f*****g snow pi** off :lol:
Re: carb jetting
john21z wrote:hi has any one got any tips about getting them back on?.
There easy enough to get back on once you know the technique.
It takes me about 2 minutes to put the carbs on if that.
The float heights should be 6.8mm.
Could be a leaking float if there overfuelling lots
john21z
Re: carb jetting
Post by john21z »
apart from a visual (obvious damage to the float bowl) is there any other way to check them. cheers john
Re: carb jetting
john21z wrote:apart from a visual (obvious damage to the float bowl) is there any other way to check them. cheers john
The carbs should shut themself off when they are full of petrol.
Since the tap is vaccum operated the fuel will shut off anyway.
If you put the carbs on a bench, use a pop-bottle etc for a temp fuel tank and fill the carbs up... they should stop taking petrol after a few seconds... if theres a leaking float, after a few minutes one of the carbs will be over-flowing.
Check the jets are clean / float heights are correct, pilot screws are set properly and the air filter is clean
