nc21 brake calipers
john21z
nc21 brake calipers
anyone know were i can get the rubber bits n bobs of a nc21zh brake calipers(not the seals) cheers john
- thunderace
- Bike owned: R6, YZF600R
Re: nc21 brake calipers
You mean the slider rubbers? Try David Silvers. The parts you want are the same as the NC24 if that helps search the site. Oh, the rear is also the same as the early Hornet 600 too
David Silvers sell them. (http://www.davidsilverspares.co.uk)
45133MA3006 Boot B
45132166016 Bush Pin A
2 of each, last time I purchased was under 3gbp for the one and under 2gbp for the other so less than 10gbp for 4.
Just search by part number and put that in and away you go
45133MA3006 Boot B
Chrissy_J
- Bike owned: VFR400Z NC21
I get mine through eBay, from a seller in Sheffield : Powerhouse Automotive. If you enter the part number into the search box you'll find what you need. I've had other parts from them too, and they're pretty efficient with good postage costs.
john21z
cheers guys thanks for all your help
