carb clamps nc30
leerc
carb clamps nc30
in cammos guide it says remove top clamps-mine only has one on each
Re: carb clamps nc30
Your NC30 is missing parts thenleerc wrote:in cammos guide it says remove top clamps-mine only has one on each
The carb rubber has two clamps, one to hold it to the engine, one to hold the carbs to the rubber.
Without it the bike will be more prone to air leaks.
lukemillar
I have a few spares kicking in the garage. If you PM me you address I'll chuck 4 in the post.
Luke
Luke
leerc
this is looking like my splutter-i went to my local bike shop to see if i could get some clamps (and failed) and he said it will more than likely be leaking lower down and once it gets to a decent rpm it'll seal itself
