Hi all, I have in my grubby mitts a 2010 r6 reg/rec, it has 6 pins.
I also have the matching plug with about 6 inches of cable coming out of it, three white wires in a row and above that a red wire and a black wire with a blanked off pin connection between them.
As there are only 5 wires going into this reg/rec and the sixth pin is not in use, can this be used on my NC30??
If it will work, I take it I would be better off to use the original R6 connector soldered to the nc30 loom?
Graham.
R6 reg/rec from 2010 bike, work???
- Bike owned: NC30,
- thunderace
- Bike owned: R6, YZF600R
Re: R6 reg/rec from 2010 bike, work???
Should work fine. I fitted one to my NC24 with no problems. As in your case, I had the bit of R6 loom as well so I spliced that onto the NC loom.
- Bike owned: NC30,
Goody goody, I think my original reg/rec is working ok, but as this one cost me diddly squat, I figured a pre-emptive strike was called for!
All i could find using search was people saying that it had to be the r6 one from before 2005, due to having 5 pins instead of 6. Hoping that as this one has one not in use, it would be ok to use, just wanted to check before cuting loom!!
