NC29 valve help
paddy_nc29
- Bike owned: NC29 x 2
NC29 valve help
Coming to do my valves, got everything off down the actually checking the valve clearance. However, as per haynes I cannot work out what valves are my inlets and exhausts for whatever cylinder.
All that it says is 'EXL INL EXR EXL' or them sort of markings. I align T1 marking and it says to check cylinders 2 and 4 inlet valves
Where are they, I could do with a diagram showing me which valves are which and what cylinder they belong to...
dunkenb
Re: NC29 valve help
can you not work out by number of valves? i.e. 4 per cylinder and the in lets on the carb side exhausts at the front??
or are you pulling our legs you cheeky monkey?
- Davez29
- Bike owned: NC29 forever
Re: NC29 valve help
Got to say having never done this before myself until last year I had the very same question, although I thought it was as you say the thing that threw me was the EX/IN printed on the cam heads. Hence I asked that very question.dunkenb wrote:can you not work out by number of valves? i.e. 4 per cylinder and the in lets on the carb side exhausts at the front??
paddy_nc29
Re: NC29 valve help
Cheers, what is the cylinder order 1324?
phil x
- Bike owned: 2 x 650 Transalp's, '90 nc30
Re: Re: NC29 valve help
No. That'll be the firing order.paddy_nc29 wrote:Cheers, what is the cylinder order 1324?
Cylinders are 1234 from left to right as if you were sat on the bike, the inlets are at the rear/carb side of the engine - 2 inlets & 2 exhaust valves per cylinder.
Are you sure that you are up to this - it's all quite basic stuff.....
Phil
paddy_nc29
I appreciate your reply, however, it's the first 4 stroke i've ever worked with, every other bike i've had is a 2 stroke all being single cylinders.phil x wrote:No. That'll be the firing order.paddy_nc29 wrote:Cheers, what is the cylinder order 1324?
Phil
Got to start somewhere haven't you and besides, this forum is here to help when unsure with something, is it not? Will check the clearances tommorow, thanks for the help all
