nc23 end can options
- si.likes.guiness
- Bike owned: nsr 250 sp
can anyone help with a bit of info please? do other bike cans fit onto the 23? ive seen an old fireblade can going cheap and wondered if it would fit ok,cheers
Re: nc23 end can options
Are they 3 bolt jobbies? or slipons?
- si.likes.guiness
oops sorry,i should have said
its 3 bolt mate from the early blades
get an adapter to fit a slip on then mate
Graeme France sells them for not a lot..then any 2 inch can from anywhere and you are sorted!
- si.likes.guiness
ah cheers for that
DK-Tandy
- Bike owned: CBR400RR NC23
or do what i did, fit any slip on can, cut the end flush, take the cap off, line upp the 3 holes from the pipe, drill, weld a nut on the underside of the can face, put it back on and re-rivet it and you've just made a slip one can fit the 3 bolt from your exhaust pipe :)
tanuki
Si, as it's going to be a trackbike if you are not that arsed just cut the flange off the end of the system and as said any 2" cans a good un (or buy a reducer as also already said)
Steer clear of anything over 420mm in length as it won't create enough back pressure, the difference is really noticeable.
- si.likes.guiness
cheers,i did pass on the blade can as i thought it would be to big/long,so would possibly be not right.i think i will just cut it as you say mate
thanks again for the replies
