crash bobbins? help needed.
- xivlia
- Bike owned: Ducati 749 D
okay. so ive done some research on crash bobbins...there are different types for uk and jap specs? ive seen some that are 99 quid!! im not prepared to pay that much for it.....ive seen these on ebay
http://www.ebay.co.uk/itm/HONDA-VFR400- ... 3a6ecb425a
and was wondering where they connect to. and will this go on a jap spec bike?
thanks for the help :)
Re: crash bobbins? help needed.
have a look through my thread, i know i asked the same question before buyin mine
viewtopic.php?f=24&t=23958
cant remember the correct answer though, iirr its the jap bikes that can take the frame bobbins. those bobbins linked are for the frame, check to see if you have 2 threaded holes either side of you bike just infront of the front cylinders.
I have those e-bay ones on my '30 and they are equal quality to RnG ones which I also have (but scuffed
For £26 they are one of the best bargains I've had off e-bay in a long while
Not sure if they'd fit you bike though, sorry
- xivlia
hmm okay, so where did you install them to? do you have a picture? would help alot!!vfrderek wrote:I have those e-bay ones on my '30 and they are equal quality to RnG ones which I also have (but scuffed)
did you check tio see if you have the holes i said!? they go there.
- xivlia
oh okay. i shall check tomorrow, my bike is still locked up in the college shed...havent seen it in 2 weeks!
i have the coyote moto ones, the bolts are wank/idea, however the bobbins are spot on, i drilled the mounts out to 10mm dia and ran a M10 threaded rod through and bolted them against each other that way the impact force is spread across the engine and not on the individual engine mount,
you will need to cut two half moon shapes in your lower fairings.
Rick
Rick
