NC30/35 Titanium - Wheel, Hub & Yoke Nuts
Concrete Jungle
Bike owned: NC 35
Re: NC30/35 Titanium - Wheel, Hub & Yoke Nuts
Post by Concrete Jungle »
How the heck have I managed to miss this thread 'til now? :o
:rocks:
Off to http://www.projection-components.co.uk/ ... ts-2-c.asp for a browse! :drool:
porndoguk
Post by porndoguk »
Drunkn Munky wrote:
porndoguk wrote:
Drunkn Munky wrote:So are you guys drilling the spindle for the hub nut and using a R clip?
YEP, will need to use an Rclip other wise you wont get the paddock stand in brother :)
Eh?? you mean to get the paddock stand in you need to remove the R Clip?
EDIT: Ok it might help if i read the 1st post of the topic :oops: as you were ignore me :grin:
i love you tony, your so special!
porndoguk
Post by porndoguk »
THEY'RE HERE
Will get the torque wrench out this evening :D
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
porndoguk wrote:THEY'RE HERE
Awesome :grin:
www.projection-racing.com
www.pjcfasteners.com
Delboy
Post by Delboy »
C'mon Rick!! :lol:
Got your spare calipers here by the way ;)
Kayla850
Post by Kayla850 »
Rumour has it the hub nuts are fine... I'll get a pic up when I get the pic to put up :grin:
As the NC30 top yoke nuts are delayed, I'll change the offer to just the rear wheel parts (hub and wheel nuts, pinch bolt) and leave the top yoke nuts separate so both NC30 and NC35 owners can take advantage. I'll put the hub nuts on sale now, and adjust the offer settings on the site to take £5 off the total price when you buy all three at once.
edit- right, that's done.
porndoguk
Post by porndoguk »
tested the hub nut and hub pinch bolt both are Spot on,
only issue ive had is the bloody hub is a nightmare to drill so going to get some better 3mm drill bits,
ill also put all the torque settings to save you having a mooch through.
Hub Pinch Bolt, 17mm hex, 3mm lock wire holes, 55nM
Hub Nut, 46mm hex, 3mm lock wire holes, 165nM VFR - 205nM RVF
Wheel Nut, 36mm hex, 3mm lock wire holes, 120nM
Yoke Stem Nut, 140nM VFR - 105nM RVF
hunter
Post by hunter »
porndog you beat me to it,
But i'v got to show mine off just the same,
And say a big thanks to Kayla,We must get some Kissing smilies,Then we can all send them to Kayla,thanks again.
The swing arm don't do them justice,it' my spare.
Kayla850
Post by Kayla850 »
I've got to say a huge thank you to Rick for testing these for me, and to the others who helped with parts and measurements and finally a massive 'phew!' that they're ok :lol:
zebulon
Post by zebulon »
Kayla, just ordered,could't wait for the to yoke. :drool:
Any plans for more Titanium? Front axle for example? :pray:
