nc21 rear shock
john21z
nc21 rear shock
hi does any one know if the rear shock on a nc21z is the same as a nc24
Re: nc21 rear shock
No but they should be interchangable.john21z wrote:hi does any one know if the rear shock on a nc21z is the same as a nc24
The NC24 has revised engine internals (much closer to what ended up in the NC30) than the NC21 and of course the single sided swinger but the frames are idential (you can transplant the NC24 swinger no trouble)
NC21: 52400ML0013
NC24: 52400ML0731
As you can see it's only the last 3 digits that are different, this indicates a newer revision to the shock, the basics are the same.. perhaps the spring rate or gas are slightly different to accout for the (presumably) heavier SS arm of the 24.
If your struggling for a shock and theres an NC24 one cheap it should drop right in without affecting the handling too much.
john21z
Re: nc21 rear shock
Cheer's Neo good info. I have never done this procedure before, so have you got any tips on where to start and what to do?
Thanks,
John.
Thanks,
John.
