NC30 Click sound on braking
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
I'm sorting out suspension issues and I get a click sound from that front that is also sensed through the handlebars when braking hard and another click when I stop braking. The click comes not at the beginning of the braking but seems to enter at a certain fork compression. Front also feels very soft but does no bottom out. I weigh about 85kg. Could it be that the headrace bearing is making the noise? I changed the front break system as a unit recently (calipers, pipes, master cylinder to a very good condition used original one) but that did not eliminate the click. The headrace bearings were changed about 10000km ago together with the front and rear wheel bearings and the rear wheel bearing disintegrated and came out in pieces two weeks ago, how long are these parts supposed to last, surely more than that right? What kind of suspension upgrade do you recommend? I want to keep the front end original except for internals and don't have much money.
Re: NC30 Click sound on braking
The front brake discs are 'floating'
They click / rattle when applying the brakes sometimes.
krisztian_andre
That's strange because I didn't have this for 2 years
cbr400rrn
- Bike owned: NC29 CBR600F
Check the head bearings for any play in them
cbr400rrn wrote:Check the head bearings for any play in them
indeed, if its' suddenly started then it's likely to be something worn, headbearings, fork bushes.. i've had clikcing ones before.porndoguk wrote:cbr400rrn wrote:Check the head bearings for any play in them
magg
- Bike owned: VFR400
Do you get the noise on every heavy brake application or only after a few repeated applications and everything has warmed up.
dgunthor
assume you don't mean the click from the brake light microswitch? just checking!
Mudguard brackets, there known for making that noise when worn. Id check your head race bearings first tho
Username
- Bike owned: VFR400RK, VFR750FK, VFR750FH,
Maybe the pads are moving within the caliper? I've had this before.
