NC35 HRC velocity stacks
- Bike owned: XT600Z,'10 TE250 ,XS650 chop
Can any one tell me how the height of the 30mm HRC stacks are measured?
Is it 30mm from the airbox tray or from the mouth of the carb?
- Yakama
Re: NC35 HRC velocity stacks
I think its the physical lenght of the velocity stack
30mm is the height that it sits above the carb, not the whole stack length.
As I thought,it's the amount it protrudes into the airbox, thanks.Cammo wrote:30mm is the height that it sits above the carb, not the whole stack length.
- Bike owned: Hondas, Ducati, Suzuki, Vespa
Do yo have some, are you get some made ??
- Bike owned: NC35
Rick oliver already sells replica short stacks.999Gomerz wrote:Do yo have some, are you get some made ??
Never truly understood how exactly they work though
- Bike owned: ktm200exc gsxr400gk71b sv650
Most modern bikes have two piece split stacks connected to a steper motor that lift up away from the throttle bodies after a set rpm , long stacks help produce power at lower rpm, short stacks produce power at high rpm.
but I read in his parts list that he says they are 20mm not 30mm like the HRC ones, I was meaning are you getting 30mm ones made like the original HRC ones.amaechizzle wrote:Rick oliver already sells replica short stacks.999Gomerz wrote:Do yo have some, are you get some made ??
I reckon the cost would of getting them made would outweigh the benefit.
