Carb Slides Mod
400RRJ
- Bike owned: CBR 400 RRJ NC23
Carb Slides Mod
What benefits does the Carb Slides mod offer? and would it work on a NC23??
tanuki
Re: Carb Slides Mod
Are you talking about the fittin of nc24 slides into nc30 carbs mod?
And would this work on a 23?
400RRJ
Re: Carb Slides Mod
Sorry i should have explained myslef a littler better
Its the drilling of the carb slides to 2.5mm (instrustions in the document library)
tanuki
Re: Carb Slides Mod
I believe it to remove the standard flat spot on the NC30 so would be pointless on a CBR, I also have it on good authority that it doesn't remove the flat spot at all just masks it.
Re: Carb Slides Mod
It also allows the slides to lift more quickly giving slightly faster throttle response.
FWIW I've never noticed much difference.
Wozza
Re: Carb Slides Mod
Graeme says it is no longer recommended so I wouldn't bother.
tanuki
Re: Carb Slides Mod
Steven has been saying it for years but the V4 boys would have none of it......
400RRJ
Re: Carb Slides Mod
Cheers for the advise guys - think ill leave well alone
Wozza
Re: Carb Slides Mod
Do you need help with carb setup?
