Dyno thread.
				gpz900
- Bike owned: GPZ900, NC30, NC35, NSR250SE
Dyno thread.
I'm sure I remember someone saying they were going to start a thread for posting dyno graphs for NCs in various states of tune, to help other members troubleshoot and tune accordingly. Well, I searched I couldn't find one so consider it started.  If there is one already, moderators, feel free to move this.
So, this is my bike, rescued from under a pile of leaves in someone's back garden, now cleaned, serviced, painted, and tuned by RB Racing in Sydney:
Full Yamamoto system
HRC air tray
160 mains
Dyno graph, nice clean 60hp
Cheers...
Al.
HRC air tray
160 mains
Cheers...
Al.
				phil x
- Bike owned: 2 x 650 Transalp's, '90 nc30
Re: Dyno thread.
Good call. Can we make this a sticky?
Here is a graph from my 1990 'K' model Nc30.
All stock & unbutchered; airfilter, airbox, exhaust etc are standard unmodified items
The carbs have 115/118 RO supplied mains (I upped them from the original 110s) with standard float heights, standard & correct needles/tubes and 0.5mm washer under the needles.
The bike was too rich with sooty plugs & a big hole between 5-7000 rpm
I have rejetted & the bike now runs much better & I will dyno again after the winter service
Phil
 Phil
Re: Dyno thread.
Stickied for 60 days to see if there is any interest.
Found a copy of Rick (porndoguk's dyno) i'm sure he'll be along to explain the jetting and the bike. I think it was on 118/120's with a yamamoto rear / tyga can when this was done.
				kevprojex
- Bike owned: ktm200exc gsxr400gk71b sv650
Re: Dyno thread.
totaly stock nc35 over modified graph .
tyga twinstack , race foam air filter filter, 4x short stacks, 125mains all round, stock ecu.
http://img842.imageshack.us/img842/9137 ... vermod.jpg
Re: Dyno thread.
118F 120R Jets,Neosophist wrote:Stickied for 60 days to see if there is any interest.
Standard Needles,
2 x washers on each needle,
Drilled Slides to 2.5mm Dia,
K&N Panel Filter,
2 x 25mm holes in the carb base plastic tray to allow more air in,
Bandaged Standard Headers,
Yamamota half section & 330mm Tyga Can
& a FUCKED chain!
 alots changed since then and would love to take it back to kevs for another run to compare the charts
				lukemillar
Re: Dyno thread.
Just got mine back yesterday. Need to order some carbs bits as we didn't have the needles or the exact jets:
Pretty happy with this! Be interested to see what it is like with the new needles, front mains and new accl. pump diaphragm.
Setup is:
Stock motor
FCR32's flatslides:
108 MJ Front
105 MJ Rear
180 MAJ
ETV needles clip in position 4
Full Tyga exhaust (330mm oval can)
Next thing to work on is the engine build...
Setup is:
Stock motor
FCR32's flatslides:
108 MJ Front
105 MJ Rear
180 MAJ
				GF Racing
Re: Dyno thread.
Here's team GF Racing 2011 NC30 Formula spec machine.
Back with it in 2012 .... if I don't sell it first.
GF Ram Air - GF refreshed race engine - RVF Engine & Carbs - HRC CDI.
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
- mruehl34
- royster81
Re: Dyno thread.
it's running ;
120's all round
standard (dirty) filter
FI needles
0.5 shim
2mm slide hole
twin stack pipes
2.5 turns on the A/F screw
and here's the chart
and here's the video
http://www.youtube.com/watch?v=AhmKAg3mfEs" onclick="window.open(this.href);return false;
							120's all round
FI needles
0.5 shim
2mm slide hole
twin stack pipes
It's not having what you want  but wanting what you've got....Loud ,Proud and Modified ....
						- royster81
Re: Dyno thread.
it's running ;
120's all round
FI needles
0.5 shim
2mm slide hole
twin stack pipes
							120's all round
FI needles
0.5 shim
2mm slide hole
twin stack pipes
