NC35 Radiator fan on NC30
makz2008
- Bike owned: NC30, NC35
How can i fit the nc35 rad fan to my nc30?
the connector blocks are different but the fan seems to be the same with the same mounting points
the nc30 has a 3pin connector whereas the nc35 one has a 2pin connector and a wire which feeds off onto the rad to what i could only assume is the thermostat?
any help would be appreciated thanks
maks
maks
Re: NC35 Radiator fan on NC30
You can wire it up fine. The nc35 wire that runs to the rad is an earth, the nc30 has this earth wire in the connector block.
If you take a look at the wiring diagrams it should be clear, these are in the haynes manual.
makz2008
i dont actually own a haynes manual but will try get my hands on one, but before i do that do you know if the wire which goes on to the rad (ive been told its the radiator switch? :s) should be before the connector block for the nc30? because my bike just doesnt seem to have anything to go on there
I don't know sorry.
If you do a google image search for the wiring diagrams something might turn up.
makz2008
=) i would never have thought of doing that
found both wiring diagrams for the 30 and the 35
thanks for the heads up!
my friend just picked up his vfr earlier today
so i think ive got plenty of reference to use now
once again thnks for the heads up
