Re: bike wont start now? any ideas why?
Did you tighten it up properly? I used 2 copper ones last week without issue.xivlia wrote:yep got a multimeter. i shall test it later onnow i ordered proper gakets for the rear manifold to downpipe...because the copper rings didnt make a seal :\
- xivlia
- Bike owned: Ducati 749 D
i did tightend it up but if i tighten any harder the clamp just bends from over tightenining
- xivlia
Re: rear downpipe gasket.. this is the right ones?
okay i just bought the 18291-mr8-000 part number which is the gaskets for the rear downpipe to manifold...and they look exactly the same as the copper rings except they are dark grey almost brown colour..and a wee bit thicker...is that the right ones? sorry got no pics to show as my phone is broken and i dont have anther camera
Yes.xivlia wrote:okay i just bought the 18291-mr8-000 part number which is the gaskets for the rear downpipe to manifold...and they look exactly the same as the copper rings except they are dark grey almost brown colour..and a wee bit thicker...is that the right ones? sorry got no pics to show as my phone is broken and i dont have anther camera
The copper ones do work too as i've used them.
If you still can't get a seal you are not doing it right.
Make sure gaskets are in properly. exhaust pipes are nice and central so they can crush up against the copper ring
- xivlia
ah okay. il see if i can try and put them in. havent tried yet as im in college at the moment, the other thing is the pipe bracket is a little bent so it wont go into the studs unless i push it quite hard. and i have a feeling that this is causing the downpipes not to sit in centerly.
That shouldn't matter so much, there a little fiddley.
Easiest if you have the rear hanger loose so you can move the exhaust around a bit so you can get the pipes connected properly
- xivlia
clutch wont work properly? what the hell?!
okay, so i installed new clutch lever. and now it wont work properly? i tried pressing the lever...and put the bike onto gear 1 from neutral...and the chain starts to spin...okay..but when i let go off the clutch the chain still spins? wtf? the bike wont stall and when i press the lever again and give throttle the chain spins even faster?....what could be the problem....it was working before i removed the lever and put the new one in...and i didnt do any adjustments to the cable at alll..just removed the old lever and put new one in.. please help
- xivlia
Re: clutch wont work properly? what the hell?!
oh another note..im guessing the clutch is constantly engaged and wont disengage....
- missis sumner
- Bike owned: NC30 + Teapot
Have you seen my thread?
viewtopic.php?f=24&t=31148
Did you check it wasn't dragging before you changed the lever - because I didn't, and it was (or at least I've come to the conclusion it must have been).
- vfrman
- Bike owned: NC30, 1098s
Hard to say. Try to adjust the cable.
