Titanium Axles for NC29
tanuki
Re: Titanium Axles for NC29
Post by tanuki »
it appears that the RVF Axle is shorter than the 29/23/30 axle which is a pisser as I have RVF forks.
But I think a little research mate will probably turn up that the axles for the 29 are the same as a multitude of bikes.
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
Just for a start, the spindle with part number 44301-MM5-000 is used on:
CBR1000F 87-96
VTR1000F 98-05
CBR600F 91-98
NT650 88-91 (this is the bros so presumably also the NT400)
nc27
nc29
nc23
Sounds like nc35 is the same but a little shorter. CBR900 92-97 (I can measure this if it's interesting to you) is the same but a little longer, and CBR900 98-99 is the same but a little longer again. I guess if you were making these by hand then there's no real extra work in making the same thing but a bit longer or shorter, as long as you have the dimensions to hand.
selexon
Bike owned: FZR400R 2TK, CBR400RR NC29
Post by selexon »
Sounds good boys, If you have the time and would like to pull out a measuring stick, that would be great if you can supply the length of said axles and spacers.
tanuki
Post by tanuki »
I can get you the dimensions of the RVF and NSR and spacers.
PARUS
Post by PARUS »
I'm going to make following titanium replacements:
1. Front axle for cbr600rr forks + calipers mounting bolts.
2. Read axle + caliper bolts.
3. Conversion kit for CBR900 42 teeth sprocket + nuts
4. ?????
If anybody interesting - let me know, I'll check the price.
selexon
Post by selexon »
I've machine the axle down to the correct width and length, just need to bore it out and tap the thread.
Current weight is .378g un drilled/bored. So only have 78g to lose then we are lighter then the std axle.
Pleiades
Bike owned: 2008 R6 Race Bike
Post by Pleiades »
selexon wrote:I've machine the axle down to the correct width and length, just need to bore it out and tap the thread.
So, is the finished product going to be a tube or a rod? I may well be interested, just depends on the budget, and of course on how much weight it saves.
I'll be up in Sydney over Christmas, so if this happens, I could pick it up and save the postage.
